Custom Speaker Box
02TAHOELT
Miami,Florida
Does anyone know someone that does a good job, i want someone build a box for a 10" or 12" in Fiberglass,Wood, or anything else there using to make boxes now. For Stock location of Subwoofer.
What speaker works/needs the smallest Air Space possible? Because i would love to cram a 12" instead of a 10"
You're going to have to go to a custom shop to have a fiberglass enclosure built to maximize the air space. But fiberglass jobs get expensive. I would normally charge roughly about $400-500 to build a glass enclusure to fit a 12" in the stock location. You're also going to have to look for a lower profile sub, one with a shallower mounting depth than most subs. Earthquake and Infinity makes a special purpose shallow sub. Best thing would be just to check out your local custom car shop.
sixty9fordkiller
Los Angeles
The best setup ive heard on a Hoe (that's not an insane setup i.e 100,000 watts 20,000 amps and 10,000 subs) was my friend's 02. He had 2 15" CVR kickers on a ported box (trapezoidal shape box with apline head unit, clairon pre amp, epicenter bass enhancer, using 1 Hifonics Brutus Mono Amp) That truck would make classical music bump if he wanted to do so! That truck bumped so hard that it made airplanes fall from the sky, trains derail, pregnant ladies think they were going into labor. Im not kiddint that is a sick setup for a tahoe for only a little bit of $$$ compared to other setups worth a lot more and that dont bump nearly as good
