Shade Tree 77
- Nov 30, 2014
Hello everyone. I just replaced my intake manifold (plenum and lower) on my 98 Tahoe. The intake gasket blew and I was puffing white smoke. The gasket was visibly blown at the coolant ports, and the lower manifold showed significant pitting on the mating surface. After replacing the gasket and manifolds and buttoning everything up, I tried to restart the vehicle and could not.
Thinking I had possibly installed the distributor 180 degrees off (even tho I marked it), I tried to rotate the damper to TDC, but the crankshaft nut will not turn. I removed the spark plugs and saw a little coolant on the spark plug from the #3 cylinder. Tried to crank the key in case it was hydrolock from coolant spilling into the other ports, but nothing blew out the plug holes. Can someone help? I'm at a loss :/
