The Tahoe is cranking but it won't turn over and idle. It's been sitting for about 6 months and the battery has been dead. I connected jumper cables and charged the battery the entire time I was messing with it, which was about an hour. Once the battery had a little charge, I tried starting it and the entire time it sounded like it wants to run but it won't stay on.
Here is what I've attempted to do to get it running.
1.) Put a little gas in the carburetor
2.) Checked the air filter; it wasn't too bad.
3.) Checked the spark plugs connected to the distributor cap
4.) Made sure radiator was full
5.) Checked the oil levels
6.) Added more gas in the tank
7.) Checked the fuel relay fuse; it's in grey plastic so not sure how to check if it's blown.
8.) Checked the fuel filter, which was dirty and probably needs to be replaced.
None of this has worked.
Should I try replacing the fuel filter or does this sound like it could be something else?
