Climate Control Issues
armorplate
Virginia City, Nevada
Greetings All!
New to the forum so bear with me. Here's the breakdown of my issue....
The speed selector for my heating and a/c unit functions in all speeds except high speed.
I already replaced.....
Resistor
Climate control unit
Help
adam74
MAGNOLIA TX
bad resistor usually will make the blower motor work on high only since it basically tones down the voltage to make it run at lower speeds. thats maybe not actually how it works but you get the idea lol.
what year is it? might help to know
adam74
MAGNOLIA TX
possibly relay, thats what controls the "high" speed. otherwise theres a connection thats known for this problem in late 70s to 90s gm vehicles. found this...
Start at the blower motor. Its wires will be purple and black. The blcak one goes to the chassis; the purple one goes to the relay, which has a plug with 5 wires in it. One of those wires is a thick red one. Follow that wire across the engine bay, under the windshield cowl; about at the right valve cover, you will come to a connector, of monumentally STUPID design. Its meltable plastic housing is actually responsible for holding the tension on the 2 metal parts, which gives an absolutely ironclad unstoppable GUARANTEE that it will fail. You will find that it is burnt to ashes.
Cut the terminals off of both of the thick red wires joined by the above connector. Throw them, and the remains of the connector itelf, into the nearest govt-approved toxic waste incinerator for proper disposal. Replace them with the BIG WIDE THICK slide terminals. Not, the little weenie ones that are just like the ones with the small red ends; the BIG THICK yellow ones. They're about half again as wide and as thick as the standard ¼" ones. Fully insulated is best; but if you can't find them like that, use some sleeving, heat-shrink, a thick wrap of tape, or something, to keep this connection which has hard battery on it, from touching something and starting a fire.
Then enjoy your high speed blower again.
Next, remove your HVAC control head from the dash. Find th e"mode" switch, near its center. It will have a number of wires that go to the fan speed switch and elsewhere. One of those wires will be brown. Follow it about 12" back into the dash, to where it plugs into the brown wire that supplies 12V to the entire HVAC system. You will observe that it is the same idiotic design from the pen of the same moron. Replace it as well, so that next week, you're not forced to post something about "my whole HVAC system stopped working".
adam74
MAGNOLIA TX
no problem. had to look at it again. mine would only work on high when I got it, researched and found that the resistor would do that and the relay controls high. remembered the wiring thing after a second too. mines a 95 ls
armorplate
...alright, relay was replaced and the high setting is still a no go. I'm wondering if a there is a specific wire which clips into the climate control unit that could have come loose. Dreading having to dig into the wiring but I'm out of ideas.
Check at the speed switch, could have a burnt up terminal or bad switch....
Yeah, its fun, bruised my arm pretty good getting mine out, remove the glove box, reach back on top of the duct there is a plug with about 4 wires that plug into a plate with 2 screws (7mm), also a bracket to the left with the relay and an extra screw.
