Can someone help me locate the blend door actuator on a 2004 Yukon with auto climate control? Mine is blowing only thorugh the windhield vents and searching leads me to this as the likely culprit. This happened for the first time after a dead battery. I wil try disconnecting the battery tonight for 15 minutes and let it recalibrate as someone here suggested.
Previously on rare occasion we would get heat on the passenger side vents only with the A/C on. That was usualy fixed by turning the CC on and off a few times.
Thanks!
Thanks!
