Catalytic Convertor
Malones99
I need to get new convertor's for my 99. Is there a bolt on? When I'm under their it looks like welds to me. I one I see at Kragen comes with the pipes form the exhaust manifold back $400, want to spend less than that.. Is there a place I can just by the convertors only? BTW I also live in Cali:mad3:
JennaBear
CA
You could probably also slip fit them and clamp em if you wanted to. I have the Magnaflow cat converters and don thave anything bad to say about them.
Malones99
Do the magna flow "slip fit". If so whick Magnaflow do you have?
JennaBear
CA
If you have the room under your Tahoe, then yes they can slip fit. I had to have mine welded as I had long tubes put in. The part number for the ones I am using is MagnaFlow 94106CA.
memphisboi55
hey, my engine light was on a few months ago and i had to get my converter replaced as well.
i ordered this off ebay: item # 330233207902
and took it to my local muffler shop to put it on
havent had any problems at all. engine light went away and passed my state inspection
