I bought the one from the dealer which uses compression nuts in the holes under the hood. The two on the drivers side went in fine. The two on the passenger side did not.
One would not compress and the other started to but not to the point where it stays in place when running a bolt in it.
Has anyone had this problem? Do the other brands use compression nuts?
Thanks for the help.
