Brakes
96cherry
livonia
ok so i just realized that my brakes were getting spongy, if im sitting at a light the pedal will eventually sink to the floor. it doesnt matter if i pump the brakes 20 times the minute it remotely gets stiff it will start to sink again. im thinking its the master cylinder but could be wrong, just looking for everyones input thanks.
Rick90467
Arkansas
See if you can get a rebuild kit for the master cylinder. More than likely it is the seals have shrunk or distorted. If it were most any other component you would not get a stiff pedal at any time.
96cherry
livonia
found the seal kit, looks like it might be a pain in the ass to change them, but ill give it a shot
mygreen98
adjust rear brakes, bleed, system. if still pedal fade, change master cylinder.
