05TahoePPV
- Nov 18, 2011
Okay, how's this for a strange one. A friend and I are trying to start a business, a police driving school,and purchased an '05 Tahoe PPV out of Chicago. He flew up, drove around Chicago for a day or so and then drove it back to TX, no problems. After driving it around the area (Ft Worth) he noticed that it would slow down while driving on the freeway without reason. In fact, enough that he had to give it more throttle to keep up with traffic. Then it would go back to normal. Upon taking it to our driving area for some testing it first did well, making several runs doing some very aggressive driving. But after a few more runs the brakes started binding up. It would move but in drive with your foot off the brake it wouldn't move and you had to give it fuel to get it to move. Having worked on cars most of my adult life and being very familiar with the basics I thought it was just the rear brakes.
We let it cool down and the brakes completely freed up. But after just a little more aggressive driving, not nearly as much as earlier, it started binding up again. This time we raised the rear off the ground and could barely turn the rear wheels by hand. Then just to make sure, did the same to the front and they were also binding up. This told us that it must be something to do with the ABS since it's all four brakes. We let it cool again and removed the circuit breaker/fuse for the ABS, not knowing if it was an electronic or mechanical issue. It still had the same problem, basically eliminating electronic ABS involvement.
Now it gets really strange. It sat for about two months, undriven, and when we tried to drive it again the problem got really bad with just some very slow easy driving. So bad that the front brakes locked completely up! It had to be forced against the front tires skidding to be moved!!
Unfortunately the Tahoe is not close to either one of us so we can't run out and check things very easily but if anyone has ANY idea what might cause this please chime in. I know this is long but you can't help if you don't know details. Thanks for reading!!!
