Roman
I had an issue not too long ago where a 60amp fuse located in the engine compartment was blowing. It was causing my passenger side windows and seats not to work. I had to replace it 3 different times. All of a sudden my third brake light would come on at different times of the day. It would stay lit until I wiggled the wiring harness by the brake pedal. I thought it was the brake switch. One night the light came on and when I wiggled the harness, i saw a huge spark and I heard the fuse blow. The next morning I took a closer look and saw the E- brake pedal bracket touching the main electrical harness. I removed the tape and saw the insulation stripped off a thick pink wire and a light blue wire. That was my problem for blowing the fuse and having the 3rd light come mysteriously. Please check to see that the E-brake pedal release bracket is not rubbing on your harness. I'm sure this could have caused an electrical fire.
