I have a 99 tahoe 5.7 4wd, I've had it a few years now and it's had this issue for a while! I noticed the headlights flicker with the blinkers, and also a couple gauge needles move in unison with them. Also, my horn and windshield mister only work sometimes! The wipers themselves also only work correctly sometimes. I can tell if everything is working right just by quickly bumping the wiper switch, which should only cycle 1 to 3 times then return to the proper position. When they do this everything works fine, horn mister wipers. But when it isn't right the horn and mister do not work at all, and there's no telling what the wipers will do. Sometimes they cycle 10 to 12 times then stop vertically or pretty much where ever they decide to stop. Lately a new issue, I believe is related, popped up. The engine would turn over but immediatly stop. I can hear the pump come on, but it seems like as soon as it starts it looses spark! Just a guess, not 100% if that's what is happening. It has happened twice, with the first taking about 10 min then it would start and run fine. Only thing I did was mess with the relay box under the hood. It's loose, I noticed when I tried to open it, the whole thing lifted a little. I pushed down on it the tried to start it and it ran fine! On the 2nd it took less time to start, I did push down the box sooner and it fired up. Hasn't happened since! I am going to start searching for the main grounds to clean and secure them to eliminate them as an issue. Basically, my question is can all of these things be related? Has anyone had similar issues? And what can I do to remedy the problems. Also, some of the back lighting on the dash work intermittently. I just rebuilt the ac system, thank goodness it doesn't effect that. Btw this was all happening before I did the ac, also, I haven't added any after market electronics. It is all still the way it came from the factory. Thanks guys in advance..
