Mike S
My 02 Tahoe battery, only a month or two old, goes dead after a day or two without driving.
I narrowed the cause down to the external amp -------- used a multimeter to check amp draw as I pulled fuses, and the amp was pulling a half amp all the time.
The internet has a lot of hits about this, but the solutions offered seem to be all over the map, from having the dealer re-flash the body control module, re-flash the radio, replace the amp, replace the entire audio system with aftermarket, ETC.
Is there a definitive answer as to what the failure mode of the external amp usually is, and what the fix is?
I searched the archives, but no real solid answers found.
Thanks in advance,
Mike
Thanks in advance,
Mike
