Back up camera.
ILoveMyHoe
Where is a good spot to mount a back up camera on the 2007 tahoe? Its a license plate one. But i don't want to drill a hole in the hatch to hide the wire. Any ideas?
clkelley
Moderator
Galax, Virginia
You may check to see if there is a way to mount it to the Reese hitch in back. Not sure how well that would work though.
Buc Off
I would suspect that you could route the wiring up through the license plate lights area. This is taking into account that the unit your installing mounts to the top license plate bracket bolts. If the existing wiring is not black, you could use some wire loom to conceal it.
CIATAHOE
Southern California
you can mount the small bullet style in the same location as the factory ones and run the wires up through not a problem.
nannerb121
The one I have on my '09 Tahoe has the wiring coming out from behind the license and hooks on that ledge thing above the license. I think its a perfect spot for it, my only complaint is it's visible there and people tend to mess with it when it is parked. Sometimes i will get back in, throw it into reverse, and the camera is a bit crooked. If you were to put it there, you can find camera brackets to hook it and i would highly recommend a bracket so that people won't mess with the camera because that is one thing that is very annoying in my opinion
