Auxiliary transcoller
PondVu
Virginia
Has anyone installed an auxiliary trans cooler? I haul a 5,000 trailer/car combo and would like to keep the trans cool. If you have installed one, what type and was installation relatively "ease"? My Tahoe is an 08. Thanks PondVu
I installed a Fluidyne HD trans cooler on mine. They make great aux coolers. If you are in the market for one soon, check out their site, as well as B&M. There are different sizes depending on the gvw and weight you'll be towing. The cooler you can keep the trans fluid, the better, so going a size or two over the minimum recommendation won't hurt at all. Fairly simple installation if you're any bit mechanically inclined. Just make sure all connections are very secure. There's a lot of pressure and you don't want to lose fluid from an inadequate hose connection.
JennaBear
CA
X2
I have the B&M.
GMTech48
Chalfont, PA
I installed the GM one, no line cutting....pretty difficult but everything fits nice
pursuit2550
GMTech48, did the factory cooler come with everything needed, lines, mounting hardeware,etc. and how much did it cost. I saw it on the gm parts website for 91.00 but doent say if it come with everything.
Thanks
GMTech48
Chalfont, PA
Thanks
yes everything, I work for GM so I don't pay retail....remember to pick up a qt of Dextron VI to top off with.
GMTech48
Chalfont, PA
depends on what makes one "better"....I know nothing about the B&M...the GM one comes with 2 new cooler lines so there is no cutting involved, bracket & cooler.
The GM one is a bit harder to install as the lines are quite tricky to snake around into position.
silver02ws6
GMTech48 - Do you happen to have the part number for the trans cooler handy? I've come across a couple of different part numbers. I was going to get 12497071 but the dealer said that kit was only for the pickups. Then I found 19171483 on another site but I'm still not sure what kit is needed.
Black Dog
I have the factory one but I'm actually thinking about adding a second factory one, just don't want to block any more of the radiator's surface area than I have to. Does that sound crazy? Rather than adding one big one I just like the fitment of OEM parts...
GMTech48
Chalfont, PA
your other site is the right one....19171483
here's the official GM site:
http://www.gmaccessorieszone.com/index.php?id=132&tx_gmshopb2b_pi1[division_name]=Chevrolet&tx_gmshopb2b_pi1[vehicle_name]=Tahoe&tx_gmshopb2b_pi1[year]=2008
