Thread jacking
Could anyone tell me where the thermostat is located on the 4.8/5.3? I know that it was in the on the front end of the block on older SBC but is it about the same location on these motors? Summers here in Texas get 100 plus for several days and consitently in the 90+ range so I had planned on running a cooler t-stat and a higher concentration of water and some water wetter or Royal Purple's ICE stuff.
TS -
My '00 Tahoe 5.3L is at 97K miles now.
Runs good, have always serviced it per spec, except I've done my oil with synthetic (M1 - 5W or 10W-30) at 3K - 4K intervals with Puralator Pure One or AC Delco filters.
Was thinking of doing the following maintenance items, and was wondering what your thoughts are on it -
1. Plugs and wires (was going to use original GM plugs and wires)
2. Change alternator, water pump, thermostat, pulleys and hoses
Regarding 1., the plugs and wires, would you change them out now or at 100K even though the engine is running good?
Regarding 2., except for the hoses (which I am probably past due on), what is your experience on the life of these other items? Should folks routinely change these out at 100K miles or so, or wait for them to die first?
Thanks in advance for any info -
Alright guys, sorry about hijacking a thread, but what do you guys think about a high flow version of the same temp thermostat, any of you do it to your rides? I tow a toyhauler and when going up big hills I am constantly playing with the motor to keep the temps from pegging too high while trying to get up and over the hill (I know, get myself a diesel truck instead, I would but that is a long story). Basically, I want to help it cool off quicker then it does by getting more water to flow through the radiator and was thinking about switching mine out to a high flow model (If they make one for it) as well as some electric fans. What do you guys think?
