Andrew99Tahoe
This is to anyone that ran the wiring themselves. I'm trying to run the power wire for an amp through my firewall but don't see any areas to run it through. I know that on every other car ive ran the wiring there was factory plugs in the firewall that could be removed to run wires, but I don't see any. The only area I found is where the antenna wire goes through and there a rubber plug. If you've done this yourself, did you drill a new hole or go through the firewall in another location?
