Anyone have a trick to adjusting the headlights on the Hoes?
I recently put HIDs in and started messing with the headlight adjustments.
Now the inside (side towards high beam, or side towards bowtie) of the driver side headlight assembly is sticking out from the grille about 1/2"
It seems to be adjusted fine from the drivers seat. But man, it does not look right with the driver side sticking out past the grille.
The passenger side I did mess with, but very minor adjustments....
I did check to make sure the bulb is properly seated into the headlight.
