Adding heated steering wheel
FatBuoy
Hey all- new member here with first question.
Is it possible to add a heated steering wheel to 2016 LT? (Swap it out) I've done a bit of searching out there, and it's a bit unclear if it's accomplishable. Any insight would be appreciated.
cmatt
From what I understand, it is possible. It may require a different clock-spring to accommodate the wiring. There should be a small black connector wrapped up the the steering wheel harness wiring under the dash. That’s for the heated steering wheel.
Sent from my iPad using Tapatalk
