Hi all, i have a relatively cheap ODBII scanner which does not read the ABS codes....so I read about some guy jumping out some pins on the ODBII plug under the dash and then the truck blinks the ABS codes on the ABS light. Does this work, if so is there a site/thread that shows the pins and codes?
Thanks!
Thanks!
