Eaustin494
Hi all,
after fighting with my '96's ABS light for about a year I give up and need help. Everything I need says a code reader says I should be able to pull ABS codes through the OBD2. I have tried 9 different readers including the one that will pull codes for my Land Rover and that is almost impossible to find one that will read those codes. I get no connection. Does that mean that the control module is bad and the cause of my light or is there some other way to pull the codes?
Thank You,
Eric A.
Thank You,
Eric A.
