Hi guys, a couple things I've noticed on this Tahoe after driving it a bunch this weekend, would appreciate any tips...
- Tranny noise: This has happened twice now, both times after driving on the highway, then exiting onto local streets. Say it's stopped at a light, when I take off I hear a moderately loud grinding sound that lasts through the initial part of the take off, then goes away as the car gets up over say 5-10 mph. But every time I slow back down and then take back off, you hear that noise. Sounds like it's coming from the mid-rear portion of the vehicle, near the back of the tranny. If I then manually shift the tranny down to 3, then 2, then back to drive, the noise goes away. The truck seems to drive OK all along.
- Rough idle: Sitting at a stop light, while in gear, I noticed it idles pretty rough. The tach stays pretty steady around 500RPM, but you can feel the engine in your seat. Putting it in neutral smooths it out.
- Cold start noise: When the truck has been sitting like overnight, the first start of the day produces a pretty terrible sounding engine noise that lasts up to about 30 seconds, then sounds completely normal. Sounds almost like a diesel engine, a heavy knock.
I should point out that I have all new sparks (AC Delco), plug wires, intake filter, and fresh oil (synthetic 5W-30) + filter (AC Delco).
Would appreciate any thoughts on these issues!
