95 GMC Yukon 5.7L
A while back I had an issue with my A/C control box. It would only blow Hot air. I did some troubleshooting and when I removed the control box I found a burned up resistor on the control board. I bought a new replacement box and installed it and it worked perfectly.
Well, it seems to have happened again. A/C stopped working, so I immediately pulled the control box and, wouldn't you know it, smoked resistor. It's the larger resistor right next to the Temp control knob.
My questions are:
1) Can anyone tell me what rating that resistor is supposed to be? Since it's burned up I can't read the code. Even if I could just get a clear photo of the control board's circuit side, that would be a big help.
2) Can anyone tell me what might be causing such a heavy load on that circuit that it would burn up 2 of those resistors? I'm not very familiar with the electrical diagrams for the truck so it's hard for me to trace that circuit and figure out what all is actually using it.
Thank you to anyone that can shed some light on this.
-Weeks
P.S. - This isn't actually my first post. It's just been so long since I had a problem with my truck that I couldn't figure out that I forgot my logon info. I guess that means I've got a good dependable American truck. :waytogo:
My questions are:
-Weeks
