jeff99
i have a 99 tahoe with 200k on it. at times it shifts kind of hard between 1 and 2nd then it will go a way. only really happens at frist start up and goes a way. not a everyday thing just once and awhile. happens in the winter and summer as well. i would like to flush and fill the tranny but i have heard some good and some bad. one guy told me he did it to his k1500 and the tranny blew up two weeks later. i also heard that you should only put fluid in and not replace all at once. the build up in the tranny is what is holding it together.
i dont want to have it flushed at the instant oil change just b/c i think they are out for a buck. i have read that doing a flush and fill 4 or 5 times. taking only a few quarts at a time is the best way.
so what is the best way to go about this? drop the pan and replace the fluids? drain and refill? should i stick to the reg fluid or go to the high miles. should i replace the fliter as well.
i havent gotten under the hoe to see if there is a drian? or would i have to drop the pan. i have read about guys running the motor and taking off the tranny lines and letting the fluid pump out vs dropping the pan or using a drain plug.
if anyone can help please do so..thanks alot
jeff
jeff
