PotentialTahoe
- May 29, 2008
I have 99 tahoe 2door w/ 128k miles 4WD. Normally when I shift from park to drive, i feel the power at the brakes immediately as in I can let off the brakes and just the idle power itself will move the vehicle ahead fairly well with no use of the accelerator. NOW when I first start the truck up and wait a few minutes, I shift from park to drive and I feel a large joult, almost if the rpms were too high when the tranny went into the right gear, when I brake I can still feel the normal power under the brake pressure, but after a few minutes of driving, I now can come to a stop and then release the brakes while in drive and the truck barely moves and I have to really gas it for it to move almost as if the transmission was slipping, it doesn't rev up really high though, and I checked the tranny fluid, it is good and red, fresh. I am confused on what it is, I want to maybe say torque converter? or transmission is going. Just to let you also know I just got done towing a fairly light boat 4000lbs about 200miles, but had no problems or issues with the tow, transmission was fine then.
