Timberwolf17044
- Sep 22, 2011
Last fall I picked up a 99 hoe with 180k on it. Shortly after putting it on the road I noticed what I assumed was brake noise, put you in mind of the front pads worn so I replaced the pads. Can't say for sure now if they were completely shot or not but anyhow after replacing them I was still hearing a grinding noise whenever I applied the brakes. I just assumed it was the brakes. I recently got the vehicle inspected and while it was up on the lift I took a close look at the front diff, cv joints and wheel bearings. Everything appeared to be fine with the exception of the front diff on the driver side there was play. So I assumed a bad bearing in the diff. I picked up a used diff at a junkyard and installed. Now the grinding noise is even worse and horrendous whine when I engage the four wheel drive. I'm starting to think I've got a bad wheel bearing but what puzzles me is there is no play in left or right tire when I have them up. Any thoughts on this would be appreciated
