remove switch assembly, check for 12v on both wires when up and down are pushed. if ok, and still no window movement, remove door panel , check 12v to motor when swtch is pushed. 12v will be on one wire when up is pushed, and on other wire when down is pushed. if this exists, give motor a tap , might be stuck. if that doesnt work, suspect bad motor.
