98 Tahoe Transmission
johnb
I have a 98 Tahoe 4x4... I need to know How would you find the Transmission Code on the Service Sticker in the glove Box... and How many different Trannys did GM make for that Truck. it's a 5.7 Vortech.. and one more thing does any one in the Washington DC or Maryland area have one for Sale?
Thanks..
clkelley
Moderator
Galax, Virginia
I would "GUESS" that your truck came with a 4L60E tranny, the RPO code in the glove box however should start with an M, for example, for the 4L60E it would be M30. Below is a list of all of the Chevy transmission rpo codes for narrowing it down once you find it.
M08 : TRANSMISSION, MAN 4 SPD, BORG WARNER, 77MM, 3.50
M10 : TRANSMISSION, AUTO 4 SPD, ISUZU, ELECTRONIC CONV
M11 : FLOOR SHIFT TRANSMISSION
M13 : TRANSMISSION, AUTO 4 SPD, HMD 4T60-E, ELECTRONIC
M15 : TRANSMISSION, AUTO 4 SPD, HMD, 4T65 – E, ENHANCED
M17 : TRANSMISSION, MAN 4 SPD, MUNCIE, 76MM, 3.31 1
M20 : TRANSMISSION, MAN 4 SPD, 117MM, 6.55 1
M21 : TRANSMISSION, MAN 4 SPD, 82MM, 2.43 1
M22 : 4 SPEED H.D. TRANSMISSION (MUNCIE)
M26 : TRANSMISSION, MAN 4 SPD, MUNCIE, 76MM, 3.50 1
M27 : TRANSMISSION, MAN 5 SPD, GETRAG, 84MM, 2.46 1
M28 : TRANSMISSION, MAN, 6 SPD, BORG WARNER
M29 : TRANSMISSION, MAN 6 SPD, BORG WARNER 85MM, 2.97
M30 : TRANSMISSION, AUTO 4 SPD, HMD, 4L60E, ELECTRONIC
M31 : TRANSMISSION, 4 SPD, AUTO THM 250 CONV CLUTCH
M32 : TRANSMISSION, MAN 5 SPD, ISUZU, 76MM, 3.72:1
M33 : TRANSMISSION, AUTO 3 SPD, TORQUE CONV
M34 : TRANSMISSION, AUTO 3 SPD, THM 125
M35 : POWERGLIDE AUTOMATIC TRANSMISSION
M38 : TURBO 350 AUTOMATIC TRANSMISSION
M39 : TRANSMISSION, MAN 5 SPD B0RG WARNER, 77MM, 2.95
M40 : TRANSMISSION, AUTO 3 SPD, TORQUE CONV VAR 1
M49 : TRANSMISSION, MAN 5 SPD, BORG WARNER 77MM, 3.75
M49 : TURBO HYDRAMATIC(TH350 4 wheel drive)
M50 : TRANSMISSION, MAN 5 SPD, NVG
M51 : TRANSMISSION, MAN 6 SPD, ISUZU
M55 : TRANSMISSION COOLER
M62 : TRANSMISSION, MAN 3 SPD, 76MM, 2.85 RATIO
M63 : TRANSMISSION, AUTO 4 SPD, ZF, NON ELECTRONIC
M64 : TRANSMISSION, MAN 3 SPD, 76MM, 3.5O RATIO
M73 : TRANSMISSION, MAN 4 SPD, ISUZU, 77.5MM, 4.09 RATIO
M75 : TRANSMISSION, MAN 5 SPD, 77MM, 3.40 1
M77 : TRANSMISSION, MAN 4 SPD, BORG WARNER, 77MM, 4.07
