I have a 98 Tahoe 2dr 4wd that has 35 inch mud tires on 20 inch rims. I have raised the torsion bars so I can clear the wheels but when I took it to have it aligned I was told that the camber was 3 degrees negative and that it was at max adjustment. The knockouts were out and they were adjusted to max. I have seen a lot of post that say when you raise the vehicle the camber goes positive but both of my tires are negative but the passenger side was adjustable but the drivers was at max already. Has anyone had this problem and how did it get resolved. THanks
