I have a 95 Tahoe with the 350 TBI and it seems to have an idle issue. The truck runs and drives great, engine is a jasper reman with 30k and runs like a top. The problem is idling in gear.
It seems that every ten seconds or so like clock work the idle drops 1-200rpm then rises up to about 900rpm. You can feel the truck lurch foward as the idle rises. It then idles fine for about ten seconds and does it again.
It almost feels as if something is clicking on like the AC compressor or something that briefly lugs the engine. Would this be the MAP or IAC sensor. I would think if it was a vacum leak it wouldnt be every ten seconds all the time.
Any info or tips would be great! Thanks!
