95 hoe with many Q?
drtalksic
i have a 95 tahoe with 250000 miles on it still runs good considering but a few improvments need to be made does any one know it there is a suspention kit in some what of a reasonable price, also thinking of changing brake rotor's, pad's and drums also looking for kit for that in anyone knows of one please let me know(looking for slotted but beggers cant be choosers) , and one transmission question when i floor the gas pedal it takes a second for the hoe to go any were and it shifts real hard but if i causally accerate there are no problems moving and no hard shift, do you think its time for a new tranny or just a flush????
treepete
Genesee Twp, WI
Start at Summit Racing for your research. You can usually get rotors and pads together in a kit starting about 200 bones.
There are also conversion kits to change your rears to disc if you like. Kinda pricey for my year, maybe its available for the 95 also.
About your transmission, I will have to let one of the pros answer that one.
drtalksic
thanx i gatta another Q? today my power locks stoped working but not the windows do you know what that could be??
treepete
Genesee Twp, WI
hmm. again a pro is needed. But I think you should check the switch itself for proper connectivity, and also see if its corroded, etc.
another thing to think about is the door lock actuator.
does this happen on all the doors, or just one?
drtalksic
yes all doors i checked the connection everything seems fine there is nothing coroded and what might this door lock actuator be.??
95TwinTT
Minnesota
Your hard shifting tranny at WOT is caused by a engine that is not putting out the power expected at that throttle setting. The trans doesn't know any better and it has the pressure all the way up to handle the power expected to come through.
The trans pressure follows the TPS voltage. (throttle position sensor) The assumption is that the power from the engine is matched by the pressure it needs to make the shift. When the engine has performance issues, there is a mismatch of the power vs the trans pressure. The original settings, were for the horsepower that the engine had, when it left the factory. It may be a little less now.
The trans is not the problem here. The engine needs some work and if it is actually at 250,000, it most likely needs major work.
It is very unlikely that all of the door locks failed at the same time. Look for a common denominator. The switches are the weak link. On DC circuits every time they are actuated, there is a tiny spark. That spark leave residue that builds up. After a while, that residue begins to insulate the contacts more and more until it just will not work at all.
Most of the GM switches I have seen, are not servicable. New switches are easily found and are easy to replace. You can always uses a jumper wire to prove the switch is the culprit. If you are not sure of wiring, have a fuse in the line of your jumper so you don't fry something.
Good luck.............:thumbsup:
