95 Chevy Tahoe Starting and running issues.
havlc2u
Hello I have a 95 Tahoe with the 5.7L
Earlier this spring it started to die at random. I would pull over and then wait a few mins and then it would start again. I parked the truck so I could drive my car for the summer. I then replaced fuel filter plugs and wires still the same thing. I then replaced the fuel pump still the same thing and now if it starts it will die after just a few mins of running I then replaced the fuel pump relay and the electronic control module same thing happens. In the last day or 2 I noticed that when I turn the key on the dash indicator lights take forever to come on. If this happens it will not start its like it has no spark. I then noticed if I turn the key and the dash lights do someone it will start run for a few mins then die.
I am out of ideals on this any help would be great.
Started to suspect Ignition Control Module in Dist, but since you mentioned the dash lights issue, possible ignition switch/ Connector.
