Miataracer
- Jun 6, 2014
New member here...
My 68K 2008 LZT has developed a high frequency vibration that occurs between 72 and 79 MPH and which is accompanied by a "rumbling" which is at the same frequency and that can be felt (and ever so slightly heard). The vibration is not present below or above that speed.
Until last week it did not exist and in fact it was not present when I came off the expressway Saturday morning but was immediately present when left my destination and came back to highway speed on the way home later that day.
Since the OEM 275/55/20 Silverstone tires were readey to be replaced, I had new ones installed but there was no change. Suspecting a lost drive shaft weight, I put the car on the lift but none are missing.
The only thing I can find is that the LR wheel bearing has the slightest play when I rock the wheel top to bottom. Before I take it into the shop and have them replace the bearing, I figured I'd ask here to see if anyone has had a similar problem - and if so what they did to cure it.
Rick
Rick
