4x4 front end problem....
dave/angie
WV
I have a buddy at work that has an '03 1500 truck that he had to replace the tranny in. That part went OK. Everything worked OK for awhile (4X4 also), but now he says that when the 4X4 button is pushed, the transfer case locks in, but won't turn the front wheels. Anyone had this happen before ??? Thanks...Dave
brodg
there is an actuator on the front differential to lock the axles 90% of the time if the transfer case is spinning the front drive shaft the actuator is faulty it also has an electrical connector on it make sure the wiring is not broken.
dave/angie
WV
I mentioned an acutator to him because mine had gone out one time. It's the heat activated actuator that's bolted to the front end on the passenger side. Mine was a '90 model though. He says his '03 does not have that on it, so I don't really have a clue what engages the front end....
brodg
892824.jpg it is #10 in the attached picture unless his truck is awd and i doubt that
dave/angie
WV
That's the same part that I told him it was. Maybe he was looking at the wrong thing ......Thanks. Dave
