Hey everybody, I've been reading on this forum for a couple months now. It seems like you guys have a great community, and I want to say thank you in advance for any help or insight you guys can give me.
I have a 97 Yukon with a Vortec 350. Unfortunately, the 350 has 137k miles on it and has recently developed a knock. I've done enough self diagnosis to figure out that it is coming from the bottom of the pan and that it isn't a valve tap... So this implies a bent rod?... In any case, I have been avoiding driving it, but had to use it the other day (wife needed her truck).
Now the knock is more like a bang with a high pitched squeel or screech (metal on metal?).
Alright, so the point is that as far as I am concerned my 350 is dead. I was going to buy a 350 vortec long block and do a direct swap. But it turns out my landlord has a 1990 305 that he pulled from a Chevy pickup. The motor only has 80k on it and is apparently in good running condition.
So my question is, will this 305 just "drop" in or will I need to do a lot of modification to make this thing work?
I've been told that the intake would be the concern... but I am also worried about the ECU, motor mounts, and trans hook up... Any insight is greatly appreciated.
BTW, I know a 305 is a sad idea to replace my 350 with, but its a complete motor for $500 and money is tight for me... so if I could make this work, it would be huge.
Thanks again.
Thanks again.
