For those of you that own a 2007-2012 Tahoe, Yukon, Suburban or Denali Escalade, you might want to continue reading this post.. We may have a solution for your problem..GM Dealerships are not in the habit of wanting to replace the defective item unless you are very lucky..But you will only find the problem to come back very quickly as they still use the same material as the original one..
Our solution is an ABS Vacuum Molded plastic dash cap cover. from TXDashcovers.com ...Looks and feels like the original but are vacuum formed instead of injection moulded, lasting much longer at a fraction of the cost of original. These install over top of existing cracked or broken original dashboard with a bondflex adhesive, normally in less than 30 Minutes..Can be painted/dyed to match the original color that you currently have now..Made in USA........Visit TXDashcovers.com for more details and pricing
http://www.txdashcovers.com
