07 Hoe 4wd problem
CptJumbo
I've looked everywhere on the web and can't quite find the answer I need. Tried talking to the stealership and they wanted d@** near $300 minimum to even look at it much less repair. I just need honest guidance.
I got stuck in a driveway with almost no mud, just enough to not catch traction. Went to switch the knob from 2wd to 4wd Lo and the light kept blinking on the knob and I heard the "clunk" of the transfer case and it switched into low range, but the front tires weren't engaging. "Service 4wd" showed up on the message center, but the transfer case stayed in low range. I switched it out and ended up calling a buddy that was a freaking 2hr drive away with a Ram to pull me out of a mud puddle. :gayflag:
I've learned that it is a common problem that the switch malfunctions, but seems to me that it works if the transfer case switches? RIGHT??? Any ideas, any way to diagnose what the problem is without paying my hard earned money to the stealership? I came to the hoe realm from a 6 liter ford diesel, so needless to say I know how to turn a wrench, so that's not a concern. I mean hell i did a head gasket job in my garage and pulled the motor in about 6 hours....please somebody give me some guidance.
