04 LT HOE driver seat troubles
dave/angie
WV
OK..... I've kinda scoured the threads and haven't found what I'm looking for so here goes. The little woman's ride heated seats quit working, driver and pass side both at the same time. Switch does NOT light up at all when pushed so I don't think that it is trying to work and then timing out. It is just like there in no power and I can't find a fuse. Also, she says ( and I checked ) the power seat adjustments for the driver seat are dead. Not even trying to move like they have no power also. And again, I can find NO fuse for this either and can't find it on the schematic........:(
dave/angie
WV
Ok...... I may be onto something...... I never did find a fuse, but I did find out that the memory seat control box (under the drivers seat) controls ALL the functions that are currently NOT working. ei: the driver side power seat controls, the heated seat function in the driver and passenger side seats. SO.... I ordered a new control box from Rock Auto for around $300.00 and I'm going to take the Hoe to the stealership to see if the old unit can be "flashed" (reprogrammed) or not. If not, see if they will install the new one and "flash" it...... I'll let ya know what happens
MO Viet Vet
Soon to be Missouri
They are also known for having the insulation come off and expose wires at the back electrical plug in that can be seen from the back. There should be a 30 amp fuse in the fuse panel, also.
