03+ tahoe front seat wiring diagram
Rocaloca
I need the wiring schematics to the electric/heated front seat diagram 16 pin connector under the seat. Can anyone help me out?
Thanks
rockenthebowtie
Any time I want
If all you it for is the seat heater its going to be the two light green connetors under the seat ones for the seat cushion and the other is for the seat back cushion disconnect the connector then ohm out each seat heater element don't know specs off the top of my head but its usually the one that reads the less ohms thats going to be the one that is shorted also usually the seat back cushion heater element you can also just peel back the cushion cover it will look all burnt and toasted
Rocaloca
Thanks for the info but I don't have a problem with the heated seats. Just looking for a schematic in the pin connector and airbag connector assembly under the seat.
Rocaloca
Yeah, I converted my seats from 2002 to 2003. I figured out what was power, ground and seat belt chime, The airbag system had a seperate connector, but it seems like in 2003 they didn't have airbags in the seats, or at least the seats I bought weren't equipped with them. Ended up using a 2.2ohm resistor to trick the system into thinking they were still there so that the airbag light doesnt stay on.
Metaldrgn
Alaska
All the schematics I found were wrong for it. I have a video on YouTube explaining it. I had to reuse the heater IC from the old seat. I'll link it later or just search for it. The pins were for the passenger seat andare different for the drivers seat, but it works.
You also may be able to swap the door pnl to keep some of the other functions like memory.
https://www.youtube.com/watch?v=zn2Lwmg5NeU
Both my new and old seats had the airbag on the side. I don't know why yours didn't
