01 Tahoe - Pulling Right Consistently
doctorgillis
Michigan
New to the forum, so thanks in advance for the help!
My 01 Tahoe pulls right constantly, had bad tie rod on front right, replaced tie rod and control arm/bushings then got it aligned, didnt help. Was told the tires were tracking/bad tread, got 4 brand new tires and balance. Still tracks right!
It happens at all speeds. Any ideas what this could be?
Dropping it off for another alignment (after new tires are on) tomorrow, but its driving me nuts.
Thanks!
doctorgillis
Michigan
Took it back for an alignment and the right castor had to be turned all the way up on spec, 5.5 i believe to compensate. YOu guys ever go that high or higher out of spec on these tahoes?
Seems pretty high, i'm worried i may be compensating for a bigger problem. Thoughts?
