Register to remove these ads.
Reply
Thread Tools Display Modes
Old 04-29-2008, 08:24 AM   #1
kingkon
Tahoeforum Noob
kingkon's Avatar
kingkon is on a distinguished road
Default 2000 yukon erratic idle
hello to all. I am new to this forum and this is my last stop to find info on a problem I am having. My 2000 yukon (new body style) has a problem with the idle. Mainly when the ac is on the idle goes up and down as the compressor kicks on and off. It also does it when thier is nothing on. I was told by the dealership numerous times it was the fuel injectors. I have had them cleaned several times no help. If thier is anyone with this problem and knows how to fix it would be a great help.
thanks in advance
kingkon is offline   Reply With Quote
Old 04-29-2008, 08:34 AM   #2
Rivieraracing
Rivieraracing is on a distinguished road
Default
Try getting yourself some throttle body cleaner spray (Seafoam makes a product called "Deep Creep") and clean out the throttle body at the flapper and all around it, then also get some cleaner spray for your Mass Airflow Sensor (located between your airfilter and air tube going to the engine)(also the spray must be for your MAF, anything else might damage it). Try those, both help me greatly with my idling problem and also made my truck run better as well.
Rivieraracing is offline   Reply With Quote
Old 04-29-2008, 09:02 AM   #3
kingkon
Tahoeforum Noob
kingkon's Avatar
Default
Quote:
will try it today. Thanks
Old 05-05-2008, 08:06 AM   #4
kingkon
Tahoeforum Noob
kingkon's Avatar
Default
I want to thank you for the heads up on the Seafoam products. I did the treatment this weekend and it is a miracle. The erratic idle is gone and the yukon runs nice and smoothe now. It is amazing that the dealer changed a bunch of parts (thankfully under warranty) and could not find the problem and a simple 6$ bottle of seafoam took care of the problem. Thanks again!!!!
Old 05-06-2008, 12:18 AM   #5
Rivieraracing
Default
No problem man, I was not sure about doing it myself but finally broke down and did it, helped me out a ton on my idling problem!!
Old 05-06-2008, 06:29 PM   #6
nephite1978
nephite1978's Avatar
nephite1978 is on a distinguished road
Default
What cleaner would you recommend for cleaning the MAF sensor? Also, is it easy to unhook? Just a few wires/connectors?
nephite1978 is offline   Reply With Quote
Old 05-06-2008, 07:57 PM   #7
Mr45
Mr45's Avatar
Mr45 is on a distinguished road
Default
Mine did the same, and cleaning the Throttle Body did the trick too.
Mr45 is offline   Reply With Quote
Old 05-06-2008, 10:09 PM   #8
Yuke2K
Yuke2K's Avatar
Yuke2K is on a distinguished road
Default
I just did the seafoam thing in my 2000 Yukon SLE too, along with a pretty thorough throttle body cleaning with Deep Creep. Man, that stuff is great. I used the PCV line to suck a little less than half of the seafoam in, then dumped the rest into the crankcase and added an additional bottle to the fuel tank. My truck smoked pretty good for about 4 minutes or so, but after that it was done. Initially I didn't notice all that much difference...but today, holy hell, you can REALLY feel it once you get into the pedal a bit - the low end really got restored on my 5.3!
I'm going to run another can through next week, just to make sure that all the carbon I loosened up in the throttle body gets removed.
Yuke2K is offline   Reply With Quote
Old 05-07-2008, 12:30 PM   #9
kingkon
Tahoeforum Noob
kingkon's Avatar
Default
Quote:
I cleaned the throttle body with the seafoam "deep creep" . It removed tons of soot from the tb. I did not touch the maf sensor and everything worked awesome.
Good Luck
Old 05-07-2008, 12:40 PM   #10
Yuke2K
Yuke2K's Avatar
Default
What kingkon said. Unless you are having issues specifically related to the MAF sensor, I would NOT mess with it. The little wires running across the inside are extremely fragile and easy to screw up, which would cause you all sorts of headaches.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
