Go Back   Tahoe Forum - Chevy Tahoe Forum > 2007 + Chevrolet Tahoe / GMC Yukon / Cadillac Escalade Year Models > Technical Discussions
Register to remove these ads.
Reply
Thread Tools Display Modes
Old 10-20-2009, 03:16 AM   #1
dogger37
Tahoeforum Noob
dogger37 is on a distinguished road
Default Rough Idling 07 yukon Denali.. Come on in
Ok gang,
I have a rough idle in my denali that seems to keep getting worse. I've had it to the dealer 2 times now. The first they suckered me in to getting a fuel system cleaning that I thought was what they consider a "top end cleaning". They basically just dumped fuel cleaner in the tank and sprayed the thottle body with cleaner. I thought they were going to pull each injector and line and clean them. Second time back they say they have no idea what it is and want to now pull the injectors and lines to inspect and clean them. I said that I am not paying and they agreed to cover the expense. Im at 82,000 with a GMPP extended warranty. Has anyone else noticed a rough idle? If so have you found the cause?
Thanks in advance,
Donny
dogger37 is offline   Reply With Quote
Old 10-21-2009, 10:24 PM   #2
73shark
73shark's Avatar
73shark is on a distinguished road
Default
Disconnected spark plug wire.
73shark is offline   Reply With Quote
Old 10-21-2009, 11:23 PM   #3
dogger37
Tahoeforum Noob
Default
no dice. I changed the plugs and checked the wires
Old 10-26-2009, 04:42 PM   #4
Ajay
Tahoeforum Apprentice Member
Ajay is on a distinguished road
Default
Donny,
Take your truck to a different shop and have it put on a diagnostic tester. Should be an easy issue to target and fix.
Ajay is offline   Reply With Quote
Old 11-14-2009, 07:54 PM   #5
mikeb33
mikeb33's Avatar
mikeb33 is on a distinguished road
Default
If it is a plug or wire, it would be missing on a specific cylinder, and set a code for it. Have you had a check engine light come on?
A proper fuel injector cleaning is hooking up a machine to the fuel rail on the engine. They block off the return to the tank and this machine puts injector cleaner in and the engine runs off of that. It is far stronger than any concentration you can pour into the tank. They run the engine for about 5 minutes, rev it up a bit, and then disconnect.
mikeb33 is offline   Reply With Quote
Old 11-18-2010, 06:21 PM   #6
ezstriper
Tahoeforum Noob
ezstriper is on a distinguished road
Default
Do you have a cylinder management ?if so seen one that the lifter went bad(they bleed off to deactivate the cylinders) and if they do it at idle cause a rough idle..tuff to find...Rob
ezstriper is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
