Register to remove these ads.
Reply
Thread Tools Display Modes
Old 02-21-2009, 03:04 PM   #1
tommyadrian5
Tahoeforum Noob
tommyadrian5 is on a distinguished road
Default Need Help. 2002 Tahoe Several Problems
Hi and Thanks in Advance for any help or advice.
I have a 2002 Tahoe LT (5.3Z-Flex Fuel) with 95,000 miles which has been having a few issues lately.
1) Cold Start (<45 degrees) Rough Idle and Code P0300. When starting the car in cold weather it first revs up to 2000-2500 rpms for a few seconds, then drops down to 500 and idles very rough, nearly stalling but never actually cutting off. I often get a flashing SES light and code P0300. If it drive the car away the code goes off, and once the car warms up it idles and drives fine. I recently replaced both cats as I was getting cat efficiency low codes, that problem seems to be solved. I am occasionally getting a low voltage for bank 2 sensor 2 O2 sensor. I replaced bank 1 sensor 2 a while ago and have 3 new ones to replace the rest but haven't done it yet. Any ideas what could be going on? Could one bad O2 sensor be causing this. Why would it go away once the car is warm. Could it be dirty injectors? I use chevron techron fuel injector cleaner occasionally but doesn't seem to help.
The fuel filter was replaced prior to this winter, it did not used to do this, could they have put a bad or wrong fuel filter in? Dirty MAF?
2) Grinding noise from front wheels. I have recently been hearing a grinding noise from my front (left) wheel. It comes and goes, but when very cold is somewhat constant. It is also more apparent going around corners at highway speed. There is also groaning when braking at full wheel turn. Is this a wheel bearing? I have had 22's on the car for its whole life. The braking system was tested and checked out fine. It also has been having a problem with the ABS kicking in for no reason while parking but i think there is a TSB about this having to do with corrosion on the sensor.
ANY Ideas? THanks so much you all are great.
tommyadrian5 is offline   Reply With Quote
Old 02-21-2009, 06:12 PM   #2
MDTAHOE1
MDTAHOE1 is on a distinguished road
Default
For your first problem you probally need intake gaskets. Very common problem and your description fits it to a tee. You may want to post this in the proper section though this is for 2007+ truck people with the same year most likely can help you better
MDTAHOE1 is offline   Reply With Quote
Old 02-21-2009, 08:28 PM   #3
nc6600
nc6600's Avatar
nc6600 is on a distinguished road
Default
Intake gaskets x2. Very very common problem on these trucks had mine replaced at 75k. 2nd prob im stumped sorry i couldn't be more help.
nc6600 is offline   Reply With Quote
Old 02-22-2009, 01:37 PM   #4
tommyadrian5
Tahoeforum Noob
Default
Can i get a price estimate of how much to do this? Just so I know what to expect when i take it in?
Thanks for the help.
Old 02-22-2009, 01:42 PM   #5
Sepiroth
Spam Executioner
Sepiroth's Avatar
Sepiroth is on a distinguished road
Default
Honestly the intake job is one a fairly mechanically inclined person can do. I also agree with the intake gaskets.
Your second issue reads like a bad hub bearing. Also an easy fix.
Sepiroth is offline   Reply With Quote
Old 02-22-2009, 01:47 PM   #6
tommyadrian5
Tahoeforum Noob
Default
Thanks for both answers?
So I should be getting an intake manifold gasket and wheel hub assembly?
Old 02-22-2009, 01:53 PM   #7
Sepiroth
Spam Executioner
Sepiroth's Avatar
Default
There are nore tests needed to be done by a person that can read and interpret the scanner values. There is also one test you can do to check your intake gaskets. Using a can of carb cleaner, you can spray around where the intake bolts to the head. What you will be listening for is a change in idle.
The hub bearing. when you make a right turn, do you hear the sound on the left? Make a left turn, do you hear it on the right?
The problem bearing is on the opposite side youre making the turn
Old 02-23-2009, 03:50 AM   #8
kandywhips504
kandywhips504's Avatar
kandywhips504 is on a distinguished road
Default
yea had the same problem with the grinding, new hub assembly did the trick
kandywhips504 is offline   Reply With Quote
Old 02-23-2009, 07:30 AM   #9
TnTahoe
Tahoeforum Apprentice Member
TnTahoe is on a distinguished road
Default
fix the hub bearing first before your wheel falls off like mine
TnTahoe is offline   Reply With Quote
Old 02-23-2009, 09:28 AM   #10
Sepiroth
Spam Executioner
Sepiroth's Avatar
Default
TnHoe, you got pics of that?
Reply
Bookmarks
Tags
grinding, idle, rough, tahoe, wheel
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
