I received my Tahoe back today after spending 2 days in the shop. They hooked their diagnostic tool up and got it to repeat the random turn on with no stoppage, so they ruled out the driver's control stem. Finally, they reflashed the Body Control Module and the problem ceased and went away. It's interesting to note that I had a reflash done previously to address the BCM rundown of the battery. But this this past Saturday, I tried to start it, and the battery was almost dead. I had to jump it to start. This was the second time this happened since the reflash. Then later on that day, the washers came on and pumped dry. Then yesterday, the backup sensor stopped working, and the delayed lock started acting flukey. So I don't know if everything is related or not, but if the problem happens to you, suggest the reflash of the BCM. Although I'm out of warranty, I was not charged for the fix except for the labor to replace the washer module.
EDIT- Shark, it's suppose to cycle 3 times before shutting down. Mine just keeps pumping and wiping. You have to cycle the ignition to get it to stop, then it won't work at all.
