Register to remove these ads.
Reply
Thread Tools Display Modes
Old 09-23-2008, 10:47 AM   #1
tommyadrian5
Tahoeforum Noob
tommyadrian5 is on a distinguished road
Default Rear A/C Not Working 2002 Tahoe
My Front A/C works great, but my rear A/C only blows air between outside temp and Hot Hot Hot. If i turn the rear a/c to full cold it is the outside air temp, if i turn it to full hot it gets very hot.
I referenced this thread below, which suggests replacing the actuator, but before I drop 90 on a new actuator I wanted to ask if a bad actuator would cause it to do what it is doing? Since it seems to work (heat is hot) could it not be that?
http://www.tahoeforum.com/showthread...r+conditioning
I notice that when i have the front and rear a/c 'on' the refrigerant line after the front rear split is cold for the front a/c and warm for the rear a/c at the splitter. Is this due to the bad actuator or do i have a problem in the refrigerant line? Any advice?
My second question is what the 'AIR' fuse in the under hood elec box controls. I inherited the car from my brother and the fuse for 'AIR' is missing. Anybody knows what this controls?
tommyadrian5 is offline   Reply With Quote
Old 09-24-2008, 04:39 PM   #2
tommyadrian5
Tahoeforum Noob
Default
Nobody has any advice??? :-(
I pulled the panel off today and the actuator is working fine, moving between the two indicators for hot/cold. The blower works fine as well.
The compressor works fine and the front a/c gets cold.
It is like there is a clog in the refrigerant line, since it does not get cold like the front one does. Checked the pressure on the system, around 40 which is half ambient and should be correct (also matches pressure on my brothers tahoe which works correctly).
What would cause a lack of refrigerant flow to the rear a/c unit? Would a clogged evaporator hose cause it? I'm dumbfounded.
Old 09-30-2008, 04:21 PM   #3
tspain
tspain is on a distinguished road
Default
The rear expansion valve on the rear evaporater is stuck closed. You'll need to remove ther rear a/c case, and evaporater and replace the rear expansion valve. Be sure and evacuate the a/c system before opening a line.
tspain is offline   Reply With Quote
Old 09-30-2008, 04:47 PM   #4
tommyadrian5
Tahoeforum Noob
Default
Quote:
That makes sense. I checked the evaporator drain hose and it was fine. There was lots of mud on the connections inside the rear fender but i assume those are sealed.
How hard is the job you proposed. Should i dealer it or can a pretty competent home mechanic do it (assuming i can evacuate the system)...
Old 09-30-2008, 10:27 PM   #5
tspain
Default
Disconnect the heater lines (2,3) from the auxiliary HVAC module at the underside of the vehicle.
Disconnect the air conditioning lines (2,3) from the auxiliary HVAC module at the underside of the vehicle.
Remove the nuts (2) from the studs (1) that secure the auxiliary HVAC module to the underside of the vehicle.
Remove the safety stands.
Lower the vehicle.
Remove the right rear quarter trim panel.
Remove the electronic suspension control module (if equiped).
Disconnect the electrical connectors from the Auxiliary HVAC module.
Remove the fastener (5) for the upper auxiliary air duct (1). Carefully slide the duct up, into the headliner, until the bottom edge of the duct is above the air distributor duct.
Remove the fasteners (3) retaining the auxiliary HVAC module to the vehicle.
Remove the auxiliary HVAC module (4) from the vehicle.
Old 06-29-2010, 04:51 PM   #6
bigham
Tahoeforum Noob
bigham is on a distinguished road
Default
Found this thread and I have the Same exact problem, Is $250 to change the part and $250 to flush sound right? Other than that wanted to say thanks for this post. It helped me.
bigham is offline   Reply With Quote
Old 05-04-2012, 02:10 PM   #7
jimandkims
Tahoeforum Newcomer
jimandkims is on a distinguished road
Default
Was this diagnosis and subsequent repair the cure for the problem - just got a 2004 Tahoe Z71 with the same exact issue! How much should I expect to spend to repair? Thanks.
jimandkims is offline   Reply With Quote
Old 05-04-2012, 03:01 PM   #8
NCFD4303
Super Moderator
NCFD4303's Avatar
NCFD4303 is on a distinguished road
Default
It is a common probelm if you have had a compressor failure.
to the board
NCFD4303 is offline   Reply With Quote
Old 05-06-2012, 10:02 AM   #9
jimandkims
Tahoeforum Newcomer
Default
Not sure if it had a compression failure since I just got it but this seems totally logical. I actually am going to tap on the location of the valve - have had luck in the past of getting them to open. Thanks all.
Old 06-30-2012, 08:55 AM   #10
hendedo
Tahoeforum Apprentice Member
hendedo is on a distinguished road
Default
Did this solve your problem? Please let us know. good write up and directions for this repair. Thanks to all.
hendedo is offline   Reply With Quote
Reply
Bookmarks
Tags
rear a/c ac air
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
