Register to remove these ads.
Reply
Thread Tools Display Modes
Old 08-16-2017, 05:24 PM   #1
bigwilley
Tahoeforum Newcomer
bigwilley is on a distinguished road
Default 1995 2 Door Tahoe. 182,000 Miles on it, Randomly dies and hard starts.
1995 2 Door Tahoe. 182,000 Miles on it. TBI. Replaced fuel pump 5 years ago. Tuned up last year. Full brakes last year (the drums were a b!tch) It has been a great rig for the last 10 years but in the last 4 months I have been having an on going random weirdness.
It runs fine, when it runs, but that is the issue. About 5 months ago, I started having it die randomly while driving. It would turn right back over if I put it in neutral while driving and turn it over. Then it started having issues starting, it would take a good while to crank to start. Once started, it would (mostly) work. It finally got bad enough that it wasn't going to start and almost stranded me a few times. So it then sat for a month, once I got it back home.
I bit the bullet and had some time so I started troubleshooting it. My first thought was spark, as it seemed to have fuel and compression is fine (for a 180k motor). I pulled a cyl 1 plug, spark tested it. Nothing. Figured it was coil, replaced it. Still nothing, next was ignition module in the distributor. Replaced that and I got it to turn back over and fire, once the fuel system pressured up from sitting for a month. Turned right over. Drove it around for a bit, thought sweet, fixed.
4 days later, I have still had it cut out on me while drive 3 times (right after each other over 3 minutes, it was hot this day) but fine while driving. Started fine Monday and Tuesday, today, fine in the morning but starts really hard this afternoon. I had to turn off the ignition, cycle the gear selector, then I saw the cluster "reset" and it fired up. So now I am thinking something heat related or cluster related. The speed it will zero and not display current speed but it always comes back. It has the typical fuel gauge flutter. All the other gauges work (tach, volt, temp, oil).
I have purposely hit train tracks and bumps to see if is a loose wire / connection but nothing seems to happen. It is SOO random. Checked grounds, fine, (though ground was loose, tighten it back up when I fixed the ignition module). Charging system seems fine, the radio doesn't cut out when it dies, it is more like the ignition switch gets turned off. Tight might be that so I wiggled it while engine was running and I couldn't get it to die. So frustrated..
Edit:
Never seems to throw codes when it dies while drive, it is like you turn off the switch..
bigwilley is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
