Go Back   Tahoe Forum - Chevy Tahoe Forum > 1994 - 1999 Chevrolet Tahoe/GMC Yukon Year Models > General Tahoe/Yukon Discussion Forum
Register to remove these ads.
General Tahoe/Yukon Discussion Forum General Discussion Forum
Reply
Thread Tools Display Modes
Old 09-29-2018, 09:26 PM   #11
tahoesteve666
tahoesteve666 is on a distinguished road
Default
A little bit more data:
a) checked fuel rail. Pressure charged is 53-53.5 psi, after 5 minutes off 52 psi, after 10 minutes off 51 psi. Stopped after 10 minutes.
b) sprayed carb cleaner all over the place again on cold engine...nothing
c) pulled the radiator cap and watched response through fill port as it heated up (would only heat up to about 150 F (via dash gauge) from cold engine, idling. Fluid expansion brought the overflow reservoir from cold level to close to hot level (bit shy of it). Saw some bubbles escape to surface of the fill port, maybe a bubble every 10-15 seconds, but it was not continuous. I also used a turkey baster and pulled about 30-50 ml out and stored it in a clear water bottle. It looked very clean. I will let it cool and see if I can see any surface film but I suspect not. There was a very very very slight surface film when looking at the fill port, but I suspect that was just from internal contamination of the coolant path rather than any oil mixing.
d) I also get your point about the RPM at idle, you are checking to see if I am starving the engine correct? I checked a few other posts..seems idle should be a bit higher...and thus the comment about the IAC above?? Do you know best target idle rpm?? and is my logic/interpretation correct here?
thanks
tahoesteve666 is offline   Reply With Quote
Old 09-29-2018, 10:24 PM   #12
east302
east302 is on a distinguished road
Default
Here is the spec on the idle, GM gives the value with the transmission in drive.
What is the scanner showing for coolant temperature (as reported by the ECT sensor)? Iím not sure what thermostat you have, but would expect it to report around 190-ish when warmed up.
Sent from my iPhone using Tapatalk
east302 is online now   Reply With Quote
Old 09-29-2018, 10:37 PM   #13
east302
Default
Quote:
Originally Posted by tahoesteve666 View Post
so a followup question on the misfires..
Is it possible for the scanner to indicate 0 misfires across all cylinders but not be an exactly accurate representation of realiy? in other words, ..can i strictly believe the scanner...is it absolutely definitive? if it is 100% reliable, then doesnt this mean I can eliminate spark and fuel out of any potential issue (real or imagined)?
The VCM is reporting the misfires based on the CKP and CMP sensor readings, so Iíd say that if itís not reporting a misfire then itís not seeing a misfire.
Your idle speed looks comparable to the scanner reading that I saw on my 98 the other day.
Old 09-29-2018, 10:47 PM   #14
tahoesteve666
Default
From the previous work and data I collected using the ELM, the warmed engine was holding steady at 194 F, not sure which PID this was offhand, would have to rerun to confirm. (While the radiator was just flushed, we didnt take tremendous care on the mix ratio, we just approximated since we thought there was probably leftover water in the system from the final flush rinse.) Seems this is thermostat controlled anyway.
I will check the in-gear idle RPMs tomorrow..but it sounds like Im not far off, if at all, from where it should be.
Old 09-30-2018, 04:46 PM   #15
tahoesteve666
Default
Update on the data:
a) So in a previous comment I referenced 150F on the dash... basically, this was the first small 'bar' above the larger mid 'bar' on the gauge, but I checked it against the ELM and the elm was indicating 88-89 C (194F) at this point. So basically, the dash gauge seems pretty much worthless other than as a reference to nominal.
b) I performed some scanning under 3 conditions: 1) engine off/battery on (obviously)/cold, 2) engine on/cold, 3) engine on (warm). I would say that getting info under '1' is suspect as many of the parameters seem to have stored values from history and dont reflect anything about current state, especially since the engine is not even on. Data under '2' is tricky also as all sorts of transients are occurring and represents open loop initially. Data under '3' seemed most reliable and stable', more accurately represents actual driving and is closed loop.
c) For the RPMs, I used PID 221191 (TCC Slip Speed), 221192 (Desired Idle) and 0c (RPM). They were consistent and with warm engine and parked , as indicated previously, it was 625 +/- for all and in Drive (Brake on obviously) it dropped t0 550-560 rpm for all. Quiver present under all conditions tested.
So summarizing my data interpretation so far: Idle RPM fine, Fuel Pressure fine, Tire Size correct, No apparent misfires via scanner, Engine Temp fine, no external leaks, carb clean spray does nothing, no codes/no CEL, coolant fluid quality looks ok, fluid levels look ok. And my quick spark plug probe seem to show all plugs plug reacting but MIL Evap not ready still exists
Interpretation: Probably dont need IAC replace for one. Think injectors, compression/leak and internal vacuum leak as only possibilities
Plan: Will still clean throttle body, probably will replace IAC when new arrives just to test and then replace original and keep new as spare. Will pull sample of hot engine oil and do visual analysis once cool. Then reevaluate again (Im trying to push off compression and injector work as much as possible as I cant see or move well anymore)
Old 10-18-2018, 01:24 AM   #16
tahoesteve666
Default
Heres an update: So I check fluid levels and it seems Im losing coolant..quite alot actually, but I see no external leaks and the previous pressure test was good. I topped off the fluids again and going to monitor it to confirm. For the hell of it, I baselined the vibration magnitudes using a tablet with a a downloaded app and measured in 3 physical locations inside the cab, just to get the feel of it. Consistent signal for a given location, but location to location had significant variation.
a) Waiting for a block tester and test fluid to show up just to check to see if any combustion gas is making it into the coolant path.
b) Also waiting for some coolant dye to confirm lack of external leaks, if any signal in the exhaust and will also check the plugs after doing a radiator pressure test with the fuel line disabled, as well as without plugs again white paper and see if anything shows there.
c) planning on compression test as well
d) will pull radiator cap again and see if any bubbles
e) will pull a sample of oil and check on a hot plate for bubbles vs smoking
f) will repeat the radiator pressure test as well once that tool comes in (previous one was not mine) and really make sure whether its holding...or more likely..determine when its holding and when it isnt!!! Going to to try running this hot after an open cap warmup.
not sure what else to do for now, but really want to make sure about any core leak issues..will post results once tools come in.. Any thoughts/suggestions..please chime in..thks
Old 10-19-2018, 06:52 PM   #17
tahoesteve666
Default
Bit more info: Engine warmed up, cap off radiator, 87 C on the coolant temp, heater on high and blowing hot, I think it was 157 F (I may have spaced and it might have been 147 F, but I tend to think 157 F) off the middle console vent. Absolutely no oil vapor on the inside of the window shield with defroster cranked, nor did I see any drips in the cabin under the dash.
a) block tester showed up, absolutely no color change on the test fluid, so thats really good news.
b) dye has not shown up yet but I did take a closer look at the exhaust, not a trace of any white smoke. There were moisture drops. I put a nice white sock to collect it, smelled it, seemed like just water to me from the CxHy + O2 -> CO2 and H2O type reaction..but I will check with dye once it arrives.
d) really no signs of any bubbles, which I think is supported by both the test fluid test and the fact that after multiple pumps on the tester bulb, I was generating some level of vacuum as the tester bulb would not fill up and simply held collapsed state until I broke the gasket seal and allowed air to enter.
Old 10-20-2018, 05:50 PM   #18
tahoesteve666
Default
Bit more info. Did a oil smoke test on material captured from the dipstick using a pump, shortly after running hot.
There were small bubbles evolved, but nothing violent. I suspect the small bubbles are simply trapped gas inside the oil from all the turbulence of running the engine, rather than incorporated coolant from a leak. I think a better test would have been to pull vacuum on the extracted oil in a clear container, prior to the smoke test, but Im not set up for that. I will have to rig something up for that...but my current interpretation is no coolant in the oil, but it is not conclusive.
Old 10-31-2018, 06:41 PM   #19
tahoesteve666
Default
So here is the latest on this issue:
a) ran dry compression test: Driver Side: 155, 172, 130, 162 - Pass Side: 180, 155, 180, 185. so I would say there is one cylinder (130) with a definitely issue. Tried wet on this cylinder also and it improved only to 135.
b) did end up changing cap, rotor, wires and plugs also
c) added mechanic in a bottle...Bars HG-1 and followed directions to the letter. did seem to help the extent of moisture in the exhaust, will have to watch it to confirm though...as the weather is changing alot and want to be sure no contribution from that.
d) also had added dye to the coolant (prior to HG1) and checked exhaust, but did not really see anything, nor did I see anything obvious on the old plugs when they were later removed and inspected.
e) latest tank of gas was only 9 mpg....lower than he 11 mpg before
so basically, Im still questioning coolant loss, low mpg, vibration (at idle only, I dont really notice it otherwise). And since the HG1 is recent, i topped off the coolant, refilled the gas tank and will put a tanks worth of mileage on it and reevaluate things (coolant loss, mpg and idle vibration primarily) and post then...
Old 11-17-2018, 04:26 PM   #20
tahoesteve666
Default
Followup ..probably final for this issue.
MPG after a tank or two of fuel is now right at 13mpg in the city (easy driving).
Vibration still there, but I dont seem to be losing much coolant now.
I do notice the thermostat seems to open up initially a bit later than normally. Dash temp gauge peaks to about 210. Then, when it first open, it cycle low to about 150, but after that it is pretty stable at 190.
I fully believe vibration is a result of the compression imbalance (cyl 3 low). Will update if it craps out, but I suspect I'm stable for awhile.
Reply
Bookmarks
Tags
rough idle, vibration
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
