Go Back   Tahoe Forum - Chevy Tahoe Forum > 1994 - 1999 Chevrolet Tahoe/GMC Yukon Year Models > General Tahoe/Yukon Discussion Forum
Register to remove these ads.
General Tahoe/Yukon Discussion Forum General Discussion Forum
Reply
Thread Tools Display Modes
Old 08-12-2017, 02:20 PM   #1
CamKota56308
Tahoeforum Newcomer
CamKota56308 is on a distinguished road
Default Coolant Leak
I was wondering if anyone can help me. I feel like Im at such a loss right now. I own a 1999 Chevy Tahoe 5.7L and yesterday it was spitting and sputtering acting like a loss of power. I pulled out the spark plugs and noticed they had some oil and coolant on them so I changed all plugs and then also changed the air filter at the same time. Everything seemed ok after that. This morning I started the truck and was on my way to the county fair with my kids about 30min away and I got 1/2 way there and stopped at a gas station to get something to drink. I came out of the store and noticed something leaking so I crawled under the truck and stuck my hand out and coolant was dripping onto my hand coming from the back of the engine. We quick headed for home and got home safely but as soon as we put cardboard under the truck the leak began to get worse and worse within moments. Yesterday when we replaced the spark plugs and air filter the coolant res tank was right on the COOL line so we know everything was ok then but this morning its leaking bad. I took a bunch of photos while under the truck hopeful someone can help point me in the right direction. Just boggles my mind that the levels were great last night and now this morning it does this out of the blue. I hope my photos can help someone help me. I dont have the funds to go to a mechanic. I am pretty mechanical myself but just cant figure out where the leak is coming from. Thank you in advance for any help someone can provide.
CamKota56308 is offline   Reply With Quote
Old 08-16-2017, 11:19 AM   #2
sntrym95
Tahoeforum Apprentice Member
sntrym95 is on a distinguished road
Default
Sounds like an intake manifold gasket or a head gasket, or both. The head gasket can cause both oil and coolant in the cylinder. The intake gasket would typically be just coolant in the cylinder, and leaking out the back, but if the gasket broke in the right place, oil could be vacuumed up from the oil galley into the cylinder.
When you turn off the engine, pressure will build in the cooling system due as it's absorbing heat from the engine still, but not flowing. So seeing a leak a few minutes after shutting off the engine indicates some part fo the cooling system is failing on the higher pressure.
I'd start with pulling the intake and inspecting, then replacing the gaskets. You'll have three gaskets on the Vortec - one on the upper plastic manifold, and two on the lower (one for each side against the heads).
sntrym95 is offline   Reply With Quote
Old 10-23-2017, 03:05 PM   #3
GermanDude
Tahoeforum Newcomer
GermanDude is on a distinguished road
Default
Mine had the same problem. Almost. It was not leaking, but the water disappeared. At the end it was the intake gasket which was broken in direction to the firewall.
GermanDude is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
