Go Back   Tahoe Forum - Chevy Tahoe Forum > 2007 + Chevrolet Tahoe / GMC Yukon / Cadillac Escalade Year Models > Audio, Video and Alarm Discussions
Register to remove these ads.
Audio, Video and Alarm Discussions This forum is for discussing audio and video topics. Such as upgrading or repairing your A/V system.
Reply
Thread Tools Display Modes
Old 08-27-2008, 11:55 AM   #1
cpizzle
Tahoeforum Noob
cpizzle is on a distinguished road
Default Door/Key in ignition chime coming through speakers
I just installed a 4 channel amp in my '08 Tahoe. I used the stock stereo and the high level inputs on the amp as opposed to using a RCA converter. Sounds great but now the door/key in ignition chime is coming through this amp and coming out the speakers very loud! What can I do?? I would like it gone altogether or just turned down. THanks!
cpizzle is offline   Reply With Quote
Old 08-27-2008, 12:54 PM   #2
AZSCTACO
AZSCTACO's Avatar
AZSCTACO is on a distinguished road
Default
Did you tap into the front speakers or rears???? When i did the same set-up as you....I tapped into the rears and had no problems with the door chimes being loud.
AZSCTACO is offline   Reply With Quote
Old 08-27-2008, 01:30 PM   #3
cpizzle
Tahoeforum Noob
Default
tapped into both. It had inputs for the front and rear so the fader works. I could play with turning the gain on the amp down and just will have to turn the stereo up more but it sounds pretty good now and I don't want to go that route.
Old 08-27-2008, 10:29 PM   #4
Grounded
Tahoeforum Apprentice Member
Grounded is on a distinguished road
Default
the chimes output is on the Left front speaker, so when you put in the amp it amplifies the chime as well. You can use the front right channel and feed into the Left in on the amp and this would kill the chimes. The only draw back is you will lose Stereo Left/Right at the amp......
Grounded is offline   Reply With Quote
Old 08-28-2008, 01:25 PM   #5
CaliChevyV8
CaliChevyV8's Avatar
CaliChevyV8 is on a distinguished road
Default
Is there anyway to shut the chime off completely? I have an 08 and it's stock, but I'd like to eliminate that chime
CaliChevyV8 is offline   Reply With Quote
Old 08-28-2008, 01:54 PM   #6
Gambler
Gambler's Avatar
Gambler is on a distinguished road
Default
Unfortunately your turn signals are also amplified the same way. You'd lose those if you lost the chime.
Gambler is offline   Reply With Quote
Old 08-28-2008, 02:22 PM   #7
DofD
DofD is on a distinguished road
Default
A thought, not saying it's a good thought ;-), could be to leave the left front channel through the OEM amp and run that to a new speaker under the dash. Then use the left rear channel to feed both the front and rear left channels (yes, you'd loose fade). At least then the chimes and such wouldn't be going through the new amp.
DofD is offline   Reply With Quote
Old 08-29-2008, 02:05 AM   #8
cpizzle
Tahoeforum Noob
Default
There's got to be a way to get rid of that chime without losing fader or stereo sound. Crikey!!!
Old 08-29-2008, 02:47 AM   #9
uegdesigner
uegdesigner is on a distinguished road
Default
Man I hope so I have the same issue and its driving me crazy! Damn its LOUD! My only idea is to figure out what wire is the signal for the loudness and add a potentiometer inline to lower the volume. Its what the harnesses that allow for lowering chime/onstar volume. Its worth as shot...
I would hate to have to wire my left front speaker with the rear signal as my front. Does anyone know if the rear sound is the same exact output as the front?
uegdesigner is offline   Reply With Quote
Old 08-29-2008, 12:23 PM   #10
DofD
Default
In part it depends on what OEM you have, but in general the OEM amp just takes stereo input and then does processing and equalization to create the multichannel output.
The question on chimes, etc would be what is the source of the chimes? Does the amplifier create the sound or does another module create them. If anyone has an answer to that, then we may be able to figure out a solution.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
