Register to remove these ads.
View Poll Results: Easiest way to add HORSEPOWER
Power Programmer 60 42.55%
Cam 15 10.64%
Cold Air Intake 33 23.40%
Headers 13 9.22%
Cat-Back Exhaust 10 7.09%
Cops R Behind You... 10 7.09%
Voters: 141. You may not vote on this poll
Reply
Thread Tools Display Modes
Old 08-02-2013, 12:07 PM   #31
amtronic1
amtronic1's Avatar
amtronic1 is on a distinguished road
Default
Way back. 40 years ago, the Chevrolet dealership I worked at used ATF to do the same thing. At that time we just poured it into the carb instead of a vacuum line. Let it set, the chunks of carbon would blow out the exhaust like birdshot when started again. Always replaced plugs as part of the process. They had us do it on everything from Vegas to Corvettes.
amtronic1 is offline   Reply With Quote
Old 08-03-2013, 06:20 PM   #32
samotahoe
samotahoe is on a distinguished road
Default
Quote:
Originally Posted by Gregski View Post
oh god one of these questions, jk, LOL
cold air won't add squat, that is significant anyway, neither will cat back exhaust, and by significant I mean dyno tested at the rear wheels gain of 10% or more
so we are left with software vs hardware, well a lumpy cam will give you crappy idle if real power is what you are after and it's a good weekend spent on the swap, but anyone who knows a wrench from a screw driver will tell you that a cam swap alone is as effective as sucking on a titty through a sweater, in order to do it right you need to marry the proper valve springs etc in the attic of the heads, then there is the chip, ah yes fooling the engine into running a certain way despite of what the sensors map may tell it, [ahem] or as the glossy marketing ads say "freeing up horsepower", that's it
tongue 'n cheek gentlemen, tongue 'n cheek
AMEN!
samotahoe is offline   Reply With Quote
Old 08-07-2013, 10:23 AM   #33
Beeker702
Tahoeforum Apprentice Member
Beeker702 is on a distinguished road
Default
I did programmer, cold air, accel coil and distributor, E3 plugs, headers, magnaflow y-pipe with converters and flowmaster catback muffler and got 100+hp over stock
Beeker702 is offline   Reply With Quote
Old 08-17-2013, 01:10 AM   #34
gary350
gary350 is on a distinguished road
Default
Quote:
Originally Posted by Biggwaukegan View Post
What is the easiest way to add horsepower????:iq: ..Without the engine or tranny swap.
There are 2 easy ways to get more power from the engine.
1. Put 10% Kerosene in the gas it will give you 10% more power and the engine will burn 10% more fuel. You can put 20% kerosene in the gas to get 20% more HP it burns 20% more fuel. Do NOT go any higher 25% and 30% Kerosene makes the engine run very bad. Diesel fuel works too I tried them both and can't tell that one works better than the other. Just incase your afraid to try this in your vehicle try it on your lawn mower first. Let your grass get too tall for your lawn mower after trying to mow grass put 20% kerosene in the gas then mow your tall grass and see the difference. Now the mower will go where it would not go before.
2. Everyone knows the laws of physics, cold contracts, hot expands. Remove your engine cooling system thermostat and replace it with a flat washer with a 3/4" diameter hole in the center. You can make a flat washer from thin flat plate aluminum. With your cooling water circulating all the time the engine runs very cold. Air that gets sucked into the air intake does not expand in the intake so your engine gets more air. More air = more oxygen. More oxygen means the engine can burn more fuel. This is an old Hot Rod trick from the 1950s.
I have a 1997 GMC Yukon and a 1999 Chevy Tahoe. This works on both of them. Now I am into getting better gas mileage sold the Yukon. Tahoe is getting 18.5 mpg in town 23.5 on the highway.
gary350 is offline   Reply With Quote
Old 12-05-2013, 08:58 PM   #35
lesterl is on a distinguished road
Default
Gary, they didnt have engine controls in the 1950's...... The PCM watches the CTS and adjusts fuel mix to suit it, you will use more fuel as the engine will still be cold...
lesterl is offline   Reply With Quote
Old 10-18-2014, 09:21 PM   #36
gary350
Default
Remove the radiator cooling system thermostat, this is an old hot rod trick. I have been told it can increase HP about 5%. A 350 hp engine will be about 367 hp.
Another trick is add 20% kerosene to the gasoline. This will add 20% hp. A 350 engine will be 402 hp.
Both of these tricks together will make a 350 engine 437 hp. More power = less gas mileage.
I put kerosene in my lawn mower when mowing tall grass and weeds wow it makes a very noticeable difference 20% more power but the fuel burns up 20% faster.
I don't want more power in my 1999 chevy Tahoe I want better gas mileage. I am getting 23.5 mpg making the engine run hotter and making the computer think it is running hotter with all new thermostats. I went to Auto Zone told the guy I want 10 engine thermostats. I checked all the thermostats with an OHM meter they are all plus or minus 5% so I picked the lowest ohm thermostat and put that in my vehicle. I bought the hottest cooling system thermostat too and the lowest ohm air temperature thermostat. My engine is probably 50 HP less but I don't miss the power. If you do the opposite of what I did you get more power and burn more fuel.
Another thing you can do to get more vehicle power is replace your tired with smaller diameter tires. Engine HP is the same but if tire diameter is reduced by 2" torque goes up about 10% do the math for your tires to see for sure. C=81.64 for 26" diameter tires. C=75.36 for 24" tires. That is a difference of 8.3%. If your top speed is 100 mph it is reduced to 92 mph. If torque is 375 at the wheels it goes up to 406.
Old 11-14-2014, 01:37 AM   #37
taho3fan
taho3fan is on a distinguished road
Default
Adding a cat-back exhaust can help add some hp and improve the sound of your ride.
taho3fan is offline   Reply With Quote
Old 11-15-2014, 02:29 PM   #38
raiderron
raiderron's Avatar
raiderron is on a distinguished road
Default
IMO, the easiest way to add horsepower? Hmmmmmmmmmmm?
First win the lottery, we all know how easy that is.
Then sit back with a pitcher of margaritas and pay lots of money to watch other qualified people bolt on whatever you want on your rig to go faster.
Or know that someone has already done to their rig what you wanted done and then buy it!
Easy peasy!
raiderron is offline   Reply With Quote
Old 10-15-2015, 08:34 AM   #39
tonymania
tonymania is on a distinguished road
Default
Installing a cold air intake made a big improvement on my ride's horse power.
tonymania is offline   Reply With Quote
Old 10-15-2015, 08:50 AM   #40
gary350
Default
If you want 20% more horse power easiest way to get it is mix 20% diesel with 80% gasoline it makes the engine burn 20% more fuel and suck in more air too so you get 20% more power just by filling up the tank with a special fuel mix.
Try this with your home lawn mower to prove to yourself it works just incase you don't believe it works.
I tried different mixtures, 30% diesel the engine runs bad, 25% diesel engine runs but not good. Don't go higher than 20% diesel and 20% Kerosene works too.
After you try this next time your tank is empty buy gasoline only and your engine is back to what is was before. No tools required, nothing to buy, nothing to adjust.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertisement
Other Sponsors
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Dodge Ram Forum
Chevy Cobalt Forum
Chevy Camaro Forum
FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
TRD Forum
Central US Mopars
Southeast Mopars
Cadillac CTS Forum
Oklahoma Dodge Ram Club
Softball Forum
